メインコンテンツにスキップ
はじめに
Use this guide to replace your iHome iP1's damaged or faulty motherboard. The motherboard is located on the back of your iHome iP1 and is protected by its back cover. Although the motherboard connects all of the electronic parts in the iHome iP1, it is relatively simple to remove.
パーツ
パーツは指定されていません。
  1. Orient the iHome upside down with the speakers facing away from you.
    • Orient the iHome upside down with the speakers facing away from you.
  2. Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover. Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  3. Remove the back cover by grabbing its sides and lifting it off the iHome.
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  4. Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection. The order in which the wire bundles are removed does not matter.
    • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
    • The order in which the wire bundles are removed does not matter.
    • You may need to remove some black foam tape in order fully disconnect some of the wires.
  5. Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard. Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
    • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
  6. Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports. Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
    • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
  7. Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward. Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward. Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
    • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
終わりに
3 の人々がこのガイドを完成させました。
Sachin Shenoi
メンバー登録日: 2016年10月10日
291 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-1, Livingston Fall 2016 Cal Poly, Team 20-1, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S20G1
4 メンバー
7のガイドは作成済み
4 件のコメント
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - 返信
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - 返信
Were you able to buy the motherboard?
Rodrigo -
Rodrigo
rodrigo@r7criacoes.com.br
Rodrigo - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 1,356
