はじめに
Use this guide to replace your iHome iP1's damaged or faulty command buttons. These buttons are located on the front of the iPod/iPhone dock and are used pause/play music and change the volume of the speakers.
必要な工具と部品
Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
Disconnect the silver ribbon cable on the left-hand side by pulling away from the command buttons.
ある他の人がこのガイドを完成しました。
