メインコンテンツにスキップ
iHome iP1 30-pin Connector Replacement
必要な工具と部品
  1. iHome iP1 30-pin Connector Replacement, Dock Cover: 手順 1、 1の画像 1
    • Orient the iHome upside down with the speakers facing you.
  2. iHome iP1 30-pin Connector Replacement: 手順 2、 1の画像 1
    • Remove the two 9.5 mm Phillips #1 screws from the dock cover.
  3. iHome iP1 30-pin Connector Replacement: 手順 3、 3の画像 1 iHome iP1 30-pin Connector Replacement: 手順 3、 3の画像 2 iHome iP1 30-pin Connector Replacement: 手順 3、 3の画像 3
    • Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
    Where can I buy this part
    Soude Alibabaie - 返信
  4. iHome iP1 30-pin Connector Replacement, Back Cover: 手順 4、 1の画像 1
    • Orient the iHome upside down with the speakers facing away from you.
    necesito toda la placa madre o el diagrama para pedir una peque;a pieza que se quemo
    Teodoro De la o - 返信
  5. iHome iP1 30-pin Connector Replacement: 手順 5、 2の画像 1 iHome iP1 30-pin Connector Replacement: 手順 5、 2の画像 2
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  6. iHome iP1 30-pin Connector Replacement: 手順 6、 1の画像 1
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  7. iHome iP1 30-pin Connector Replacement, 30-pin Connector: 手順 7、 1の画像 1
    • Rotate the iHome so that the speakers are facing you.
    • Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
  8. iHome iP1 30-pin Connector Replacement: 手順 8、 3の画像 1 iHome iP1 30-pin Connector Replacement: 手順 8、 3の画像 2 iHome iP1 30-pin Connector Replacement: 手順 8、 3の画像 3
    • Rotate the iHome so that the speakers are once again facing away from you and the motherboard is still exposed.
    • Unplug the wide red/white/black wire bundle from the lower right-hand corner of the motherboard by pulling it out of their connection.
    hi,
    can i get new Board for this Device.
    kindly reply to riyupc123@gmail.com
    Riyu PC - 返信
  9. iHome iP1 30-pin Connector Replacement: 手順 9、 3の画像 1 iHome iP1 30-pin Connector Replacement: 手順 9、 3の画像 2 iHome iP1 30-pin Connector Replacement: 手順 9、 3の画像 3
    • Rotate the iHome iP1 so that the speakers are now facing you.
    • Remove both of the speaker covers by pulling them off of the faceplate.
  10. iHome iP1 30-pin Connector Replacement: 手順 10、 1の画像 1
    • Unscrew the twelve 14.5 mm Phillips #2 screws holding the faceplate to the speaker housing. (There are six screws connecting the faceplate to each speaker.)
    • Completing this step will loosen the faceplate enough to pull the bundle of cables attached to the 30-pin connector through a hole in the faceplate, allowing the 30-pin connector to be removed from the iHome.
  11. iHome iP1 30-pin Connector Replacement: 手順 11、 3の画像 1 iHome iP1 30-pin Connector Replacement: 手順 11、 3の画像 2 iHome iP1 30-pin Connector Replacement: 手順 11、 3の画像 3
    • Detach the 30-pin connector from the dock housing by pushing it through the slot which it sticks out of.
    • Sometimes the 30-pin connector can get stuck in the dock housing, making it difficult to push through. To prevent this, push each side of the 30-pin connector evenly. This step can be accomplished without the use of any additional tools.
    • The command buttons have been shown as removed to show how to detach the 30-pin connector. However, it is not necessary to remove the command buttons in order to remove the 30-pin connector.
  12. iHome iP1 30-pin Connector Replacement: 手順 12、 3の画像 1 iHome iP1 30-pin Connector Replacement: 手順 12、 3の画像 2 iHome iP1 30-pin Connector Replacement: 手順 12、 3の画像 3
    • Remove the 30-pin connector from the iHome by pulling the bundle of cables attached to it through the center hole in the faceplate.
    • You may have to wiggle the faceplate to be able to pull the bundle of cables through its center hole.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Wen Sullivan
メンバー登録日: 10/06/16
518 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 20-1, Livingston Fall 2016 Cal Poly, Team 20-1, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S20G1
4 メンバー
7のガイドは作成済み
4 件のコメント
Where can you buy a new pin connector?
shoreman19 - 返信
Where can I buy a new pin connector?
shoreman19 - 返信
Edward Voermans - 返信
where can i buy new Board
Riyu PC - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 2,463
