この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The lower case gives the iHome its flat lower surface and houses two AA batteries.This guide provides the first step in accessing the areas of the iHome where components that could need installation are located.
必要な工具と部品
Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
Remove the battery cover and the batteries.
Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
The lower case can now be completely removed from the device!
