メインコンテンツにスキップ
iHome iH8BR Buttons Replacement
必要な工具と部品
  1. iHome iH8BR Buttons Replacement, Lower Case: 手順 1、 3の画像 1 iHome iH8BR Buttons Replacement, Lower Case: 手順 1、 3の画像 2 iHome iH8BR Buttons Replacement, Lower Case: 手順 1、 3の画像 3
    • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
    • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
    • Remove the battery cover and the batteries.
  2. iHome iH8BR Buttons Replacement: 手順 2、 2の画像 1 iHome iH8BR Buttons Replacement: 手順 2、 2の画像 2
    • Slide a spudger under the two front rubber pads to expose two hidden screws.
  3. iHome iH8BR Buttons Replacement: 手順 3、 1の画像 1
    • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
  4. iHome iH8BR Buttons Replacement: 手順 4、 2の画像 1 iHome iH8BR Buttons Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
    • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
    • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
    • The lower case can now be completely removed from the device!
  5. iHome iH8BR Buttons Replacement, Motherboard Assembly: 手順 5、 2の画像 1 iHome iH8BR Buttons Replacement, Motherboard Assembly: 手順 5、 2の画像 2
    • Remove the four screws attaching the top of the case to the motherboard:
    • Two 9.5 mm Phillips #2 screws near the speaker grille.
    • Two 14.3 mm Phillips #2 screws that sit in recesses under the motherboard.
    • It is useful to use a screwdriver with a magnetic tip so that the screws don't get lost inside the device.
  6. iHome iH8BR Buttons Replacement: 手順 6、 2の画像 1 iHome iH8BR Buttons Replacement: 手順 6、 2の画像 2
    • Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
    • Prying the Motherboard Assembly from the Upper Case will require a good amount of force. Be very careful not to break the case, or yank on any of the ribbon wires attached to the underside.
    • Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
    • If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
    • Pull the back adapter cover off.
  7. iHome iH8BR Buttons Replacement: 手順 7、 2の画像 1 iHome iH8BR Buttons Replacement: 手順 7、 2の画像 2
    • Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
    • Only remove the following screws if you are planning on taking apart the iPod Adapter later on:
    • Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
    • One 4.0 mm Phillips #1 screw near the center of the adapter.
    • The iPod adapter should now be separate from the upper casing.
  8. iHome iH8BR Buttons Replacement: 手順 8、 3の画像 1 iHome iH8BR Buttons Replacement: 手順 8、 3の画像 2 iHome iH8BR Buttons Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • With the back of the iHome is facing you, tilt the Motherboard Assembly upwards as shown.
    • Do not yank or jerk these ribbon cables. Make sure not to pull on the heads, but on the ribbons themselves.
    • Use tweezers to remove the 6 ribbon cables.
  9. iHome iH8BR Buttons Replacement: 手順 9、 1の画像 1
    • Pull the speakers, motherboard, and iPod adapter up and away from the lower casing.
    • You have now separated your iHome's inner workings from its protective case!
  10. iHome iH8BR Buttons Replacement, Buttons: 手順 10、 3の画像 1 iHome iH8BR Buttons Replacement, Buttons: 手順 10、 3の画像 2 iHome iH8BR Buttons Replacement, Buttons: 手順 10、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the eight 7.9 mm Phillips #1 screws from the center board.
    • Use tweezers to carefully remove the largest circuit board.
    • You should be able to easily lift the buttons away.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
cfredric
メンバー登録日: 04/17/13
25 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-33, Amido Spring 2013 Cal Poly, Team 12-33, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S12G33
4 メンバー
7のガイドは作成済み
コメント 1 件
Suggestion here is that no parts required but if buttons broken where do I get replacements from? iHome site doesn't recognise iH8
Am in UK
thank you h
Heidi Yeo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 19
今までの合計 2,313
