メインコンテンツにスキップ
iHome iH5 Display Screen Replacement
必要な工具と部品
  1. iHome iH5 Display Screen Replacement, Display Screen: 手順 1、 1の画像 1
    • Flip iHome iH5 over so bottom is facing up.
    • Remove all eight of the screws with a #2 Phillips screwdriver.
    • The eight screws are 5/16 inch screws.
  2. iHome iH5 Display Screen Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    • Pull cover back to access the inside.
    • Use tweezers (or pliers if wires are tight) to unplug the three wires.
  3. iHome iH5 Display Screen Replacement: 手順 3、 1の画像 1
    • Remove the five screws holding the circuit board down with a #2 Phillips screwdriver.
    • The five screws are 5/16 inch screws.
  4. iHome iH5 Display Screen Replacement: 手順 4、 2の画像 1 iHome iH5 Display Screen Replacement: 手順 4、 2の画像 2
    • Flip the circuit board over so back is facing out.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Remove the eight wires from the circuit board with tweezers. If the wires are tight 8" needle nose pliers might work better.
    • There is one wire to be removed in the orange box.
    • There are two wires to be removed in the the yellow box.
    • In the green box there are five wires to be removed.
  5. iHome iH5 Display Screen Replacement: 手順 5、 3の画像 1 iHome iH5 Display Screen Replacement: 手順 5、 3の画像 2 iHome iH5 Display Screen Replacement: 手順 5、 3の画像 3
    • Remove the two 5/16 inch screws from the speakers and the bottom of the device with a #2 Phillips screwdriver.
    • Remove the two 5/16 inch screws from the speakers and the front of the device with a #2 Phillips screwdriver.
    • Gently pull the back of the speaker up (like the speaker on the right side of the picture. Then pull it straight back (as shown with the speaker on the left side of the picture).
  6. iHome iH5 Display Screen Replacement: 手順 6、 2の画像 1 iHome iH5 Display Screen Replacement: 手順 6、 2の画像 2
    • Remove the black and sliver front piece of the device.
    • Pull it up until it hits plastic pieces sticking out from the screen display. Then pull it away from the device.
  7. iHome iH5 Display Screen Replacement: 手順 7、 3の画像 1 iHome iH5 Display Screen Replacement: 手順 7、 3の画像 2 iHome iH5 Display Screen Replacement: 手順 7、 3の画像 3
    • Pull back the electron tape covering the two screws on the screen display and remove the 1/4 screws with #0 Phillips screwdriver
    • Remove the six 3/8 inch screws from the circuit board with a #2 Phillips screwdriver.
    • There are fours screws in the corners.
    • There are two screws in the middle (the wires have to be moved to see them).
  8. iHome iH5 Display Screen Replacement: 手順 8、 2の画像 1 iHome iH5 Display Screen Replacement: 手順 8、 2の画像 2
    • Remove the circuit board by gently pulling it back and up out of the device.
    • Peel back the electrical tape and move the wires out of the way.
    • Remove the two 5/16 inch screws that are now exposed with a #2 Phillips screwdriver.
  9. iHome iH5 Display Screen Replacement: 手順 9、 2の画像 1 iHome iH5 Display Screen Replacement: 手順 9、 2の画像 2
    • Remove the screen display by placing on hand on the white framing and grabbing the screen and pulling in straight back.
    • Replace the piece.
終わりに
作成者
2人の作成者と共同で作成されました。
Maggie Hill
メンバー登録日: 03/20/14
379 ポイント
3のガイドは作成済み
チーム
New Mexico State, Team 1-6, Easley Spring 2014 New Mexico State, Team 1-6, Easley Spring 2014人のメンバー
NMSU-EASLEY-S14S1G6
5 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 814
