はじめに
The iHome iH3L also functions as a clock. This guide will help you replace damaged clock adjustment buttons that would be used to set the time.
必要な工具と部品
Locate all screws on the back of the iHome. Each screw can be located by the arrows on the iHome.
Two Countersunk 9.7 mm Phillips #2 screws in the middle.
Two 15.9 mm Phillips #2 screws.
Six 13.9 mm Phillips #2 screws.
Some screws are located under the black sticky pads. Gently remove the black sticky pads and it will expose the screws.
Two 11.8 mm Phillips #2 screws.
Disconnect the final connector pin series and carefully set your lid behind the body of the iHome.
The tiny speaker will not be disconnected for this repair, but you can easily remove it from the lid by means of a paperclip from the outside. While not necessary, this can help prevent damage to your device.
At this point the buttons should be free of obstruction and easily accessible.
Unscrew the two 11.9 mm Phillips #2 screws that are holding the plastic buttons onto the body.
