メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
パーツ
パーツは指定されていません。
  1. Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic. Remove the plastic slide from its location and set it aside. These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Set the batteries aside, careful to not get them wet.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Apply force in the direction of the arrow shown above the word "Open" on the plastic. The plastic piece covering the watch battery should come loose.
    • Set this plastic covering aside as well.
  3. Remove the following screws:
    • Remove the following screws:
    • Eight 10 mm Phillips #0
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  5. Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  6. Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  7. Remove the following screws:
    • Two 10 mm Phillips #0
  8. Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
    • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
終わりに
John Kraemer
メンバー登録日: 2012年10月09日
64 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S3G21
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 189
