メインコンテンツにスキップ
iHome iD95 Bottom Cover Replacement
必要な工具と部品
  1. iHome iD95 Bottom Cover Replacement, Backup Battery: 手順 1、 1の画像 1
    • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
    • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
  2. iHome iD95 Bottom Cover Replacement: 手順 2、 1の画像 1
    • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
  3. iHome iD95 Bottom Cover Replacement: 手順 3、 1の画像 1
    • Use a plastic opening tool to take out the backup battery.
  4. iHome iD95 Bottom Cover Replacement, Bottom Cover: 手順 4、 1の画像 1
    • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
  5. iHome iD95 Bottom Cover Replacement: 手順 5、 2の画像 1 iHome iD95 Bottom Cover Replacement: 手順 5、 2の画像 2
    • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
    • Insert a plastic opening tool between the edge of the bottom cover and the main body.
    • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
    • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
  6. iHome iD95 Bottom Cover Replacement: 手順 6、 2の画像 1 iHome iD95 Bottom Cover Replacement: 手順 6、 2の画像 2
    • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
    • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
    • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
  7. iHome iD95 Bottom Cover Replacement: 手順 7、 2の画像 1 iHome iD95 Bottom Cover Replacement: 手順 7、 2の画像 2
    • Apply the same techniques from the previous step to remove the remaining side panel.
  8. iHome iD95 Bottom Cover Replacement: 手順 8、 3の画像 1 iHome iD95 Bottom Cover Replacement: 手順 8、 3の画像 2 iHome iD95 Bottom Cover Replacement: 手順 8、 3の画像 3
    • Locate the two plastic clips holding the bottom and back cover together.
    • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
    • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
    • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
    • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
  9. iHome iD95 Bottom Cover Replacement: 手順 9、 2の画像 1 iHome iD95 Bottom Cover Replacement: 手順 9、 2の画像 2
    • Use the same steps to remove the remaining clip.
    • The bottom cover is still connected to the motherboard by wiring.
  10. iHome iD95 Bottom Cover Replacement: 手順 10、 2の画像 1 iHome iD95 Bottom Cover Replacement: 手順 10、 2の画像 2
    • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
    • Don't pull the wires. Take your time using a plastic opening tool.
終わりに
作成者
7人の作成者と共同で作成されました。
Vincent Chan
メンバー登録日: 04/18/13
19 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-37, Amido Spring 2013 Cal Poly, Team 12-37, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S12G37
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 644
