メインコンテンツにスキップ
iHome iBT84 Light Fixture Replacement
必要な工具と部品
  1. iHome iBT84 Light Fixture Replacement, Motherboard: 手順 1、 2の画像 1 iHome iBT84 Light Fixture Replacement, Motherboard: 手順 1、 2の画像 2
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Light Fixture Replacement: 手順 2、 2の画像 1 iHome iBT84 Light Fixture Replacement: 手順 2、 2の画像 2
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Light Fixture Replacement: 手順 3、 3の画像 1 iHome iBT84 Light Fixture Replacement: 手順 3、 3の画像 2 iHome iBT84 Light Fixture Replacement: 手順 3、 3の画像 3
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Light Fixture Replacement: 手順 4、 1の画像 1
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
  5. iHome iBT84 Light Fixture Replacement, Light Fixture: 手順 5、 1の画像 1
    • Use the screwdriver to unscrew the screws on the left and right sides.
  6. iHome iBT84 Light Fixture Replacement: 手順 6、 1の画像 1
    • Once unscrewed, use the metal spudge to lift the base of the light fixture.
  7. iHome iBT84 Light Fixture Replacement: 手順 7、 2の画像 1 iHome iBT84 Light Fixture Replacement: 手順 7、 2の画像 2
    • Lift the base of the light fixture out with the lights.
    • Be careful. The light fixture's can be easily bent.
  8. iHome iBT84 Light Fixture Replacement: 手順 8、 2の画像 1 iHome iBT84 Light Fixture Replacement: 手順 8、 2の画像 2
    • Pull gently on the individual light fixture that needs to be replaced.
    • Place new individual LED light strip.
終わりに
作成者
3人の作成者と共同で作成されました。
Joshua Lopez
メンバー登録日: 09/25/17
101 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G3, Thompson Fall 2017 University of North Texas, Team S1-G3, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S1G3
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 569
