メインコンテンツにスキップ
iHome iBT16 Motherboard Replacement
必要な工具と部品
  1. iHome iBT16 Motherboard Replacement, Base Plate: 手順 1、 2の画像 1 iHome iBT16 Motherboard Replacement, Base Plate: 手順 1、 2の画像 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: 手順 2、 2の画像 1 iHome iBT16 Motherboard Replacement: 手順 2、 2の画像 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: 手順 3、 3の画像 1 iHome iBT16 Motherboard Replacement, Motherboard: 手順 3、 3の画像 2 iHome iBT16 Motherboard Replacement, Motherboard: 手順 3、 3の画像 3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: 手順 4、 2の画像 1 iHome iBT16 Motherboard Replacement: 手順 4、 2の画像 2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the plastic cover from the power switch actuator on the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Joseph Hazel
メンバー登録日: 03/24/17
329 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 UMass Dartmouth, Team S8-G4, Valliere Spring 2018人のメンバー
UMASSD-VALLIERE-S18S8G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,129
