メインコンテンツにスキップ
iHome iAVS16 LCD (Display) Replacement
必要な工具と部品
  1. iHome iAVS16 LCD (Display) Replacement, Power Board: 手順 1、 3の画像 1 iHome iAVS16 LCD (Display) Replacement, Power Board: 手順 1、 3の画像 2 iHome iAVS16 LCD (Display) Replacement, Power Board: 手順 1、 3の画像 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 LCD (Display) Replacement: 手順 2、 3の画像 1 iHome iAVS16 LCD (Display) Replacement: 手順 2、 3の画像 2 iHome iAVS16 LCD (Display) Replacement: 手順 2、 3の画像 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 LCD (Display) Replacement: 手順 3、 2の画像 1 iHome iAVS16 LCD (Display) Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 LCD (Display) Replacement: 手順 4、 3の画像 1 iHome iAVS16 LCD (Display) Replacement: 手順 4、 3の画像 2 iHome iAVS16 LCD (Display) Replacement: 手順 4、 3の画像 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 LCD (Display) Replacement, LCD (Display): 手順 5、 3の画像 1 iHome iAVS16 LCD (Display) Replacement, LCD (Display): 手順 5、 3の画像 2 iHome iAVS16 LCD (Display) Replacement, LCD (Display): 手順 5、 3の画像 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 LCD (Display) Replacement: 手順 6、 1の画像 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 LCD (Display) Replacement: 手順 7、 3の画像 1 iHome iAVS16 LCD (Display) Replacement: 手順 7、 3の画像 2 iHome iAVS16 LCD (Display) Replacement: 手順 7、 3の画像 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
終わりに
作成者
5人の作成者と共同で作成されました。
Marco Sousa
メンバー登録日: 10/25/19
293 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019人のメンバー
UMASSD-O'CONNELL-F19S1G7
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 187
