Make sure to flip the device over to get into the correct orientation
Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
Make sure to keep these screws in a safe location so you don't lose them
Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
Using a lever like motion, push the opening tool down thus lifting the plate
You will need to use your fingers to lift the base plate off the main body of the device
The motherboard is directly underneath the base plate
Take the motherboard out of the device, use the Plastic opening tool to ensure the power switch doesn't get stuck.
Don't pull too hard as you could possibly rip some wires or break the switch.
Take the battery out from underneath the motherboard.
The battery is connected to the motherboard, don't pull the battery too hard or too far from the motherboard.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
