メインコンテンツにスキップ
iHip Fold-up Portable Speaker iPod/iPhone Input Replacement
必要な工具と部品
  1. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the battery case cover: 手順 1、 1の画像 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cleaning the battery case: 手順 2、 3の画像 1 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cleaning the battery case: 手順 2、 3の画像 2 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cleaning the battery case: 手順 2、 3の画像 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the screws: 手順 3、 2の画像 1 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the screws: 手順 3、 2の画像 2
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the back cover: 手順 4、 2の画像 1 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the back cover: 手順 4、 2の画像 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Taking out the iPod/iPhone input: 手順 5、 2の画像 1 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Taking out the iPod/iPhone input: 手順 5、 2の画像 2
    • Locate the iPhone/iPod input that is in the center of the console.
    • Push the black plastic input stand to the left, and up, with your index finger.
    • Use tweezers to wedge the input stand out of its slot.
  6. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing iPod/iPhone Input: 手順 6、 1の画像 1
    • Pull out the iPod/iPhone input with tweezers.
  7. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the Line In Chip: 手順 7、 1の画像 1
    • Gently remove the Line In chip with tweezers.
    • Note: The Line In chip is located on the left side of the device.
  8. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cutting the Input Wires from the Line In Chip: 手順 8、 1の画像 1
    • Use scissors to cut the black, yellow, and red wires that connect the Line In chip to the iPod/iPhone input.
    • Remove the old iPod/iPhone input and its associated wires.
  9. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cauterizing the New Input Wires to the Line In Chip: 手順 9、 1の画像 1
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    購入する
    • Follow the instructions provided with the soldering station to preheat the gun before use.
    • Place new iPod/iPhone input wires, one by one, in their previous position on the Line In chip. Wrap a strip of soldering wire on the point of contact between the chip and input wire.
    • Use the soldering gun to melt the strip of soldering wire.
  10. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Replacing the Line In Chip: 手順 10、 1の画像 1
    • Use tweezers to carefully place the newly soldered Line In chip back into its original position.
  11. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Positioning New iPod/iPhone Input Into Original Position: 手順 11、 1の画像 1
    • With tweezers, insert the end of the iPod/iPhone input through its designated hole.
    • Note: The device has been rotated 90 degrees to the left in this picture.
    • With both thumbs, push in the black plastic input stand until it snaps into place.
終わりに
作成者
7人の作成者と共同で作成されました。
Jonathon Josephson
メンバー登録日: 10/13/14
103 ポイント
1ガイドが承認済み
チーム
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G4
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 233
