はじめに
This guide will demonstrate how to properly remove the fault DC IN 6V adapter and replace it with a new one.
  1. Use your fingers to slide the battery case cover off in the direction of the arrows.
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
    • Remove and discard the old batteries.
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
      • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
    • Remove the back cover carefully; there are many wires that connect it to the device.
  6. Position the portable speaker device so that the back cover and the speaker are both laying flat, giving you access to the inside of the device.
    • Position the portable speaker device so that the back cover and the speaker are both laying flat, giving you access to the inside of the device.
    • If the motherboard is at the bottom when you are looking down at the device, the DC IN 6V adapter should be on the right side of the back cover.
    • It is also labeled on the outside of the back cover in white font.
  7. Remove the black and red wires attached to both the motherboard and the adapter by cutting them with scissors.
    • Remove the black and red wires attached to both the motherboard and the adapter by cutting them with scissors.
    • Repeat previous step for the blue and second black wire connecting the adapter to the battery case.
    • At this point, you should be able to carefully remove the entire faulty adapter and the wires.
  8. Position the newly purchased DC IN 6V adapter and wires in their original place.
    • Position the newly purchased DC IN 6V adapter and wires in their original place.
    • Using a soldering iron and soldering wire, reattach the black wire from the battery case (above DC IN 6V chip) to the bottom of the DC IN 6V chip.
    • Using the soldering iron soldering wire, reattach the red and black wire from the motherboard (on the left of the DC IN 6V chip) in that respective order above the previously soldered black wire.
    • Use the soldering iron and soldering wire one last time to reattach the blue wire above the soldered black wire from the motherboard.
まとめ
Cristina Garcia
メンバー登録日: 2014年10月13日
301 ポイント
3のガイドは作成済み
チーム
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G4
5 メンバー
8のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 217
