メインコンテンツにスキップ
iHip Fold-up Portable Speaker Back Cover Removal
必要な工具と部品
  1. iHip Fold-up Portable Speaker Back Cover Removal, Removing the battery case cover: 手順 1、 1の画像 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: 手順 2、 3の画像 1 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: 手順 2、 3の画像 2 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: 手順 2、 3の画像 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: 手順 3、 2の画像 1 iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: 手順 3、 2の画像 2
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: 手順 4、 2の画像 1 iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: 手順 4、 2の画像 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
終わりに
作成者
10人の作成者と共同で作成されました。
Cristina Garcia
メンバー登録日: 10/13/14
301 ポイント
3のガイドは作成済み
チーム
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G4
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 271
