はじめに
This guide will aid in properly removing the back cover of the device. Through doing this, you will have access to the internal pieces of the device and allow in further adjustments.
パーツ
パーツは必要ありません。
  1. Use your fingers to slide the battery case cover off in the direction of the arrows.
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. Remove and discard the old batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries. Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
    • Remove and discard the old batteries.
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver. Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
      • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep 10 mm and 0.6 mm screws separate from each other for reassembly.
  5. Remove the back cover carefully; there are many wires that connect it to the device. Remove the back cover carefully; there are many wires that connect it to the device.
    • Remove the back cover carefully; there are many wires that connect it to the device.
まとめ
Cristina Garcia
メンバー登録日: 2014年10月13日
301 ポイント
3のガイドは作成済み
チーム
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G4
5 メンバー
8のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 197
