メインコンテンツにスキップ
iFit Act Battery Replacement
必要な工具と部品
  1. iFit Act Battery Replacement, Battery: 手順 1、 1の画像 1
    • Hold the iFit band in both hands, with your thumbs on either side of the tracker pod at the center of the wristband.
  2. iFit Act Battery Replacement: 手順 2、 1の画像 1
    • Using your index finger, gently push the tracker pod out of the wristband. It may help to do this over a table or other surface so the tracker pod doesn’t fall on the floor and break.
  3. iFit Act Battery Replacement: 手順 3、 1の画像 1
    • Once the tracker pod is freed from the wristband, remove the back of the tracker pod using the plastic opening tool. The tool’s curved edge should be pointed toward the back of the device to avoid scratching the front display.
  4. iFit Act Battery Replacement: 手順 4、 1の画像 1
    • Using the curved metal precision tweezers, gently lift the battery out of the tracker pod.
  5. iFit Act Battery Replacement: 手順 5、 1の画像 1
    • Place the new battery in the tracker pod. Make sure the positive side of the battery is face down in the cavity of the tracker pod.
  6. iFit Act Battery Replacement: 手順 6、 1の画像 1
    • To close the tracker pod, place the top and bottom pieces between fingers as shown and snap them together.
終わりに
To assemble this device, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Charlotte Asmuth
メンバー登録日: 09/28/15
104 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 1-1, Diaz Fall 2015 University of Maine, Team 1-1, Diaz Fall 2015人のメンバー
UMAINE-DIAZ-F15S1G1
4 メンバー
1のガイドは作成済み
2 件のコメント
The directions state that battery CR2032 is the battery for the ifit.act. I purchased this battery and it does not fit. Where can I get the battery that is compatible with ifit.act?
Revice Fisher - 返信
The original battery should have identifying markings on the top so you can purchase an identical replacement. A standard CR 2032 coin cell battery is what’s specified by the manufacturer.
Jeff Suovanen -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 39
今までの合計 15,144
