メインコンテンツにスキップ
iDevices iGrill Power Delivery Wires and Springs Replacement
必要な工具と部品
  1. iDevices iGrill Power Delivery Wires and Springs Replacement, Power Delivery Wires and Springs: 手順 1、 1の画像 1
    • Place the front screen of the device on a flat surface, this allows access to the back cover. Remove the back cover from the device to access the batteries.
  2. iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 2、 1の画像 1
    • Remove the batteries from the device, allowing you to access the screws necessary for removal of the back panel.
  3. iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 3、 2の画像 1 iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 3、 2の画像 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm Phillips screws from the left side of the internal cover.
  4. iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 4、 1の画像 1
    • Gently and slowly pull the back cover off of the iGrill, exposing the power cables to the motherboard.
  5. iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 5、 2の画像 1 iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 5、 2の画像 2
    • Gently pull the metal terminals to the batteries out of their plastic holders.
    • Position the metal terminals such that you will be able to pull the plastic component that holds the batteries away from the motherboard.
    • Remove the internal cover from the device.
  6. iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 6、 1の画像 1
    • After you have peeled back the rear plastic covering, you will have access to the motherboard.
  7. iDevices iGrill Power Delivery Wires and Springs Replacement: 手順 7、 1の画像 1
    • From here, you will have access to both the metal terminals of the power transfer wires and the soldering points of the power transfer wires to the motherboard.
    • If any of these connections have been broken, repair them with a solder and soldering wire.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Kyle McElyea
メンバー登録日: 02/16/16
259 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-4, Harley Spring 2016 IUPUI, Team 3-4, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S3G4
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 273
