はじめに
In cases where no audio is being produced, this guide will help you replace the speaker.
必要な工具と部品
Place the tablet on a flat surface, facing upwards.
Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
Place the front and back portion of the tablet close in proximity and have both of them face upwards while being cautious of the wire connecting the speaker to the motherboard.
To reassemble your device, follow these instructions in reverse order. A soldering kit will be required to ensure a connection between the speaker and motherboard after the replacement is complete.
ある他の人がこのガイドを完成しました。
