メインコンテンツにスキップ
iDeaUSA CT8 Speaker Replacement
必要な工具と部品
  1. iDeaUSA CT8 Speaker Replacement, Speaker: 手順 1、 3の画像 1 iDeaUSA CT8 Speaker Replacement, Speaker: 手順 1、 3の画像 2 iDeaUSA CT8 Speaker Replacement, Speaker: 手順 1、 3の画像 3
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Place the front and back portion of the tablet close in proximity and have both of them face upwards while being cautious of the wire connecting the speaker to the motherboard.
  2. iDeaUSA CT8 Speaker Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    購入する
    • Locate the two wires connecting the speaker to the motherboard.
    • With tweezers, gently pull the red and black wires out of their sockets.
    • A soldering kit is required to reconnect the speaker to the motherboard.
  3. iDeaUSA CT8 Speaker Replacement: 手順 3、 2の画像 1 iDeaUSA CT8 Speaker Replacement: 手順 3、 2の画像 2
    • On the tablet’s back cover, locate the two 4 mm screws on the speaker.
    • Use the #000 Phillips screwdriver to remove the screws and place them in an appropriate location.
  4. iDeaUSA CT8 Speaker Replacement: 手順 4、 2の画像 1 iDeaUSA CT8 Speaker Replacement: 手順 4、 2の画像 2
    • Using a metal spudger, safely separate the speaker from its socket.
  5. iDeaUSA CT8 Speaker Replacement: 手順 5、 2の画像 1 iDeaUSA CT8 Speaker Replacement: 手順 5、 2の画像 2
    • The speaker is now removed and can be replaced accordingly.
    • Remember that to ensure a connection, you will need to solder the new wire connections onto the motherboard.
終わりに
To reassemble your device, follow these instructions in reverse order. A soldering kit will be required to ensure a connection between the speaker and motherboard after the replacement is complete.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Daniel Sevilla
メンバー登録日: 09/20/17
412 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S7-G5, Thomas Fall 2017 University of North Texas, Team S7-G5, Thomas Fall 2017人のメンバー
UNT-THOMAS-F17S7G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 88
