メインコンテンツにスキップ
iDeaUSA CT8 Motherboard Replacement
必要な工具と部品
  1. iDeaUSA CT8 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 iDeaUSA CT8 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 iDeaUSA CT8 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
  2. iDeaUSA CT8 Motherboard Replacement: 手順 2、 3の画像 1 iDeaUSA CT8 Motherboard Replacement: 手順 2、 3の画像 2 iDeaUSA CT8 Motherboard Replacement: 手順 2、 3の画像 3
    • Locate the five 3.5 mm black screws on the motherboard.
    • Use the #00 Phillips screwdriver to remove the screws, place them in an appropriate location.
  3. iDeaUSA CT8 Motherboard Replacement: 手順 3、 1の画像 1
    • Carefully peel off the tape covering the circuit boards and blue ribbons. The tape can be disposed or saved for reuse.
  4. iDeaUSA CT8 Motherboard Replacement: 手順 4、 3の画像 1 iDeaUSA CT8 Motherboard Replacement: 手順 4、 3の画像 2 iDeaUSA CT8 Motherboard Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • After removing the tape, two blue ribbon wires can now be accessed. To disconnect, gently lift up the plastic ZIF tabs covering the wires.
    • Upon lifting the tab, the ribbons can now be safely pulled out of their connections.
    • To avoid breaking or damaging the plastic ZIF tabs, it is recommended to use tweezers.
  5. iDeaUSA CT8 Motherboard Replacement: 手順 5、 1の画像 1
    • Locate the two wires connecting the speaker to the motherboard.
    • Use a soldering iron to desolder the red and black wires from their sockets.
    • Solder the speaker wires back in place during reassembly.
  6. iDeaUSA CT8 Motherboard Replacement: 手順 6、 2の画像 1 iDeaUSA CT8 Motherboard Replacement: 手順 6、 2の画像 2
    • Disconnect the wires connecting the battery to the motherboard.
    • Start from the sides and gently wiggle the connection out until it;s loose enough to pull.
  7. iDeaUSA CT8 Motherboard Replacement: 手順 7、 2の画像 1 iDeaUSA CT8 Motherboard Replacement: 手順 7、 2の画像 2
    • Pull out and free the motherboard from its position.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Daniel Sevilla
メンバー登録日: 09/20/17
412 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S7-G5, Thomas Fall 2017 University of North Texas, Team S7-G5, Thomas Fall 2017人のメンバー
UNT-THOMAS-F17S7G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 132
