メインコンテンツにスキップ
iDea USA CT702 Battery Replacement
必要な工具と部品
  1. iDea USA CT702 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Face the tablet with portholes facing you.
  2. iDea USA CT702 Battery Replacement: 手順 2、 1の画像 1
    • Use a fingernail or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time.
  3. iDea USA CT702 Battery Replacement: 手順 3、 3の画像 1 iDea USA CT702 Battery Replacement: 手順 3、 3の画像 2 iDea USA CT702 Battery Replacement: 手順 3、 3の画像 3
    • Use your fingers to remove the rest of the back. Slowly apply pressure from each side to detach each clip connection.
  4. iDea USA CT702 Battery Replacement: 手順 4、 2の画像 1 iDea USA CT702 Battery Replacement: 手順 4、 2の画像 2
    • Separate the battery from the device.
    • Slowly use your thumb and forefingers to pry open each corner.
    • Be aware of the adhesive on the bottom of the battery. Remove with care to keep battery intact.
  5. iDea USA CT702 Battery Replacement: 手順 5、 1の画像 1
    • Carefully peel off tape around the top of the battery.
    • Slowly use your fingernail to lift the tape off of the battery. Dispose of the tape or save it for reuse.
  6. iDea USA CT702 Battery Replacement: 手順 6、 3の画像 1 iDea USA CT702 Battery Replacement: 手順 6、 3の画像 2 iDea USA CT702 Battery Replacement: 手順 6、 3の画像 3
    • Disconnect the battery using the soldering iron.
    • Remember to use proper safety precautions when soldering. Solder from the side and do not breathe the smoke in.
    • Make sure the soldering iron is on the highest heat for 5 minutes before starting.
    • Start with the red wire, and gently touch the tip of the iron onto the connection.
    • Move to the yellow wire after the red.
    • Move to the black wire after the yellow.
  7. iDea USA CT702 Battery Replacement: 手順 7、 1の画像 1
    • Remove the battery completely. Dispose of the defective battery properly at a recycling center.
  8. iDea USA CT702 Battery Replacement: 手順 8、 1の画像 1
    • Put the new battery in place
    • Make sure the corners are inside of the white shell.
  9. iDea USA CT702 Battery Replacement: 手順 9、 2の画像 1 iDea USA CT702 Battery Replacement: 手順 9、 2の画像 2
    • Solder the new battery.
    • Start with the black wire and solder to the nearest connection.
    • Move to the yellow wire and solder to the middle connection.
    • End with the red wire and solder to the farthest connection away.
  10. iDea USA CT702 Battery Replacement: 手順 10、 2の画像 1 iDea USA CT702 Battery Replacement: 手順 10、 2の画像 2
    • Re-tape the battery at the top.
    • Make sure the solder has cooled before taping.
    • Tape the corners in place, onto the shell.
    • To replace back cover, follow the first three steps in reverse order.
終わりに
To reassemble your device, Start from step 9 and work backwards.
作成者
7人の作成者と共同で作成されました。
Benton Gray
メンバー登録日: 03/11/15
201 ポイント
2のガイドは作成済み
チーム
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S4G7
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 608
