はじめに
Change out the entire display assembly, including the inverter, Airport antenna, hinges and plastic casing.
必要なもの
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Remove the following 11 screws from the bottom of the computer:
Three 3 mm Phillips around the battery compartment. (Some models may only have two screws.)
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 11 mm Phillips in the lower right corner. (if present)
Four 14.5 mm Phillips.
Remove the following 16 screws:
Thirteen 3 mm Phillips.
One 3 mm Phillips. (actual screw not present in image)
Two 4 mm Phillips.
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
If your iBook has Bluetooth, as discussed in the previous step, you will need to slide the antenna through the lower I-shaped hole in the shield before completely removing the shield.
Turn the computer over.
Disconnect the inverter cable from the logic board and deroute it from the metal framework, removing tape as necessary.
15 の人々がこのガイドを完成させました。
添付文書
コメント 1 件
Very nice guide, thanks!
I call this the “You Gotta Be Kidding Me” Era of Mac repair. The Flat Panel iMac, the iBooks… good times. If I actually get the iBook G4 running I will be most happy to update this comment.
