はじめに
Replace the display inverter with the display assembly still attached to your computer.
必要なもの
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
もう少しです!
終わりに
3 の人々がこのガイドを完成させました。
