はじめに
Replacing the plastic bottom case.
必要な工具と部品
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
もう少しです!
終わりに
3 の人々がこのガイドを完成させました。
