はじめに
Replace a broken LCD/Backlight with the display still attached to your iBook.
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
もう少しです!
終わりに
12 の人々がこのガイドを完成させました。
