はじめに
Replace your broken display hinges to make your display open silky-smooth.
必要な工具と部品
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
Remove the following 4 screws from the bottom shield:
Two 3 mm Phillips.
Two 7.5 mm Phillips.
Remove the two Phillips screws securing the DC-In board, removing tape as necessary.
Remove the two 3 mm Phillips screws inside the left edge of the battery tray.
Three 3 mm Phillips around the battery compartment.
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 12 mm Phillips in the lower right corner.
Four 14.5 mm Phillips.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle.
Carefully lift the upper case slightly and move it toward the front of the computer to reveal the trackpad connector. Use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
After disconnecting the track pad connector, carefully rotate the upper case away from you and rest it against the display.
Remove the fifteen 3 mm Phillips screws securing the top shield to the computer.
Remove the following 16 screws:
Thirteen 3 mm Phillips.
One 3 mm Phillips. (actual screw not present in image)
Two 4 mm Phillips.
Remove the following three screws:
Two 3mm Phillips screws.
One 7.5 mm Phillips screw.
Lift the small plastic retaining bracket up and out of the computer.
Turn the computer back over.
Disconnect the microphone cable at the front of the computer, between the left side of the hard drive and the metal framework, removing tape as necessary.
Although not absolutely essential, removal of the hard drive will give enough space to remove the connector with your fingers.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
Remove the two pieces of tape over the display data/microphone cables near the lower edge of the display.
Remove the two pieces of tape covering the inverter/AirPort cables along the lower edge of the display.
Remove the six Phillips screws securing the clutch hinges to the front display bezel.
Lift the clutch hinges off the front display bezel.
4 の人々がこのガイドを完成させました。
添付文書
コメント 1 件
After replacing hinges in iBook G4 12 inch, I feel I can do anything with laptops :)
