メインコンテンツにスキップ
iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement
必要な工具と部品
  1. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 2、 1の画像 1
    • Lift the battery out of the computer.
  3. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement, Rear Display Bezel: 手順 3、 2の画像 1 iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement, Rear Display Bezel: 手順 3、 2の画像 2
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  4. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 4、 2の画像 1 iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 4、 2の画像 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  5. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 5、 1の画像 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  6. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 6、 2の画像 1 iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 6、 2の画像 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  7. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 7、 1の画像 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  8. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: 手順 8、 1の画像 1
    • Lift the rear bezel off the display assembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Bookholt
586,236 ポイント
619のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 4,150
