メインコンテンツにスキップ
iBook G3 Clamshell Keyboard Replacement
必要な工具と部品
  1. iBook G3 Clamshell Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell Keyboard Replacement, Airport Card: 手順 2、 1の画像 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
    • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
  3. iBook G3 Clamshell Keyboard Replacement: 手順 3、 1の画像 1
    • If your computer does not have an airport card, you can skip the next two steps.
    • Grasp the clear plastic tab on the airport card and pull up and toward the display.
    Note to those who want to install an airport card to a laptop here that doesn't have a card. The proper orientation is with the bar code facing up, and the "Airport" artwork and logo facing down. There are small slots on the bottom of the card that fit into pins below the trackpad. You will know it is properly slotted because the top of the card will touch the handles of the RAM shield.
    The proper orientation of the antenna is that it is plugged in from the right side of the top of the airport card, with the cable winding up from the right to the left.
    Marissa Stardance - 返信
  4. iBook G3 Clamshell Keyboard Replacement: 手順 4、 1の画像 1
    • Hold the airport card in one hand and use your other hand to remove the antenna cable.
  5. iBook G3 Clamshell Keyboard Replacement, Keyboard: 手順 5、 1の画像 1
    • Remove the two Phillips screws that secure the RAM shield.
  6. iBook G3 Clamshell Keyboard Replacement: 手順 6、 1の画像 1
    • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
  7. iBook G3 Clamshell Keyboard Replacement: 手順 7、 1の画像 1
    • Pull up the keyboard connector cable by its clear plastic loop.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
コメント 1 件
I was worried about replacing the key board having never worked on a laptop before, your guide was a great help! Thank you, Dave
dave - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 9,237
