メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iBook G3 14" LCD Replacement
必要な工具と部品
  1. iBook G3 14" LCD Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 14" LCD Replacement, Rear Display Bezel: 手順 2、 2の画像 1 iBook G3 14" LCD Replacement, Rear Display Bezel: 手順 2、 2の画像 2
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  3. iBook G3 14" LCD Replacement: 手順 3、 2の画像 1 iBook G3 14" LCD Replacement: 手順 3、 2の画像 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  4. iBook G3 14" LCD Replacement: 手順 4、 1の画像 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  5. iBook G3 14" LCD Replacement: 手順 5、 2の画像 1 iBook G3 14" LCD Replacement: 手順 5、 2の画像 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  6. iBook G3 14" LCD Replacement: 手順 6、 1の画像 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  7. iBook G3 14" LCD Replacement: 手順 7、 1の画像 1
    • Lift the rear bezel off the display assembly.
  8. iBook G3 14" LCD Replacement, LCD: 手順 8、 2の画像 1 iBook G3 14" LCD Replacement, LCD: 手順 8、 2の画像 2
    • Close the display.
    • Remove the several pieces of tape securing the thin metal LCD cover to the display.
    • Carefully remove the piece of foil tape covering the display data cable connection.
  9. iBook G3 14" LCD Replacement: 手順 9、 2の画像 1 iBook G3 14" LCD Replacement: 手順 9、 2の画像 2
    • Remove the Phillips screw near the right display hinge.
    • Use the tip of a spudger to remove the small spacer under the screw you just removed.
  10. iBook G3 14" LCD Replacement: 手順 10、 1の画像 1
    • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges.
    • Leave the tape attached to the thin steel LCD cover.
  11. iBook G3 14" LCD Replacement: 手順 11、 2の画像 1 iBook G3 14" LCD Replacement: 手順 11、 2の画像 2
    • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
  12. iBook G3 14" LCD Replacement: 手順 12、 1の画像 1
    • Carefully remove the thin steel LCD cover.
  13. iBook G3 14" LCD Replacement: 手順 13、 1の画像 1
    • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
  14. iBook G3 14" LCD Replacement: 手順 14、 1の画像 1
    • Remove the strip of yellow tape securing the display data cable to the metal LCD frame.
  15. iBook G3 14" LCD Replacement: 手順 15、 2の画像 1 iBook G3 14" LCD Replacement: 手順 15、 2の画像 2
    • Disconnect the backlight cable from the inverter.
    • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
  16. iBook G3 14" LCD Replacement: 手順 16、 1の画像 1
    • Lift the LCD out of the display assembly.
    • It may be helpful to press the latch release button and open your display slightly to push the LCD out of the display assembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Bookholt
596,650 ポイント
619のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 2,955
