メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iBook G3 14" Bottom Shield Replacement
必要な工具と部品
  1. iBook G3 14" Bottom Shield Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    FixBotに聞いてみる
  2. iBook G3 14" Bottom Shield Replacement, Lower Case: 手順 2、 1の画像 1
    • Use a pin to remove the three rubber feet from the lower case.
    FixBotに聞いてみる
  3. iBook G3 14" Bottom Shield Replacement: 手順 3、 1の画像 1
    • Remove the three newly-revealed Phillips screws.
    FixBotに聞いてみる
  4. iBook G3 14" Bottom Shield Replacement: 手順 4、 1の画像 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    FixBotに聞いてみる
  5. iBook G3 14" Bottom Shield Replacement: 手順 5、 1の画像 1
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The screw in the center is shorter than the other two.
    FixBotに聞いてみる
  6. iBook G3 14" Bottom Shield Replacement: 手順 6、 1の画像 1
    • Remove the two Phillips screws on either side of the battery contacts.
    FixBotに聞いてみる
  7. iBook G3 14" Bottom Shield Replacement: 手順 7、 1の画像 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    FixBotに聞いてみる
  8. iBook G3 14" Bottom Shield Replacement: 手順 8、 1の画像 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place.
    • Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    FixBotに聞いてみる
  9. iBook G3 14" Bottom Shield Replacement: 手順 9、 1の画像 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case.
    • Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    FixBotに聞いてみる
  10. iBook G3 14" Bottom Shield Replacement: 手順 10、 1の画像 1
    • Continue to run the spudger around the front, right corner.
    • There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    FixBotに聞いてみる
  11. iBook G3 14" Bottom Shield Replacement: 手順 11、 1の画像 1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you.
    • Pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
    FixBotに聞いてみる
  12. iBook G3 14" Bottom Shield Replacement: 手順 12、 1の画像 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    FixBotに聞いてみる
    • Peel back the yellow tape and foil shielding.
    FixBotに聞いてみる
  13. iBook G3 14" Bottom Shield Replacement: 手順 14、 1の画像 1
    • Remove the following 10 screws:
    • One 5 mm Phillips at the upper, right corner of the battery compartment.
    • Nine 6 mm Phillips scattered around the shield.
    • Lift the bottom shield off.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
2件のガイドコメント
By using a T8 Torx screwdriver to remove and reinstall the three hex screws on the bottom case as suggested, I ended up stripping the screw heads when tightening them. By pushing hard on a T9 Torx driver I was able to carefully remove the stripped screws. I would recommend using the proper size hex driver instead of the T8 Torx driver for a more positive grip in the screw head.
randy3833 - 返信 共有
To add to my above comment: There doesn't seem to be a correct hex size for these 3 screws in either metric or SAE. Actually, the T9 Torx driver works pretty well. I replaced the stripped screws with three brand new ones.
randy3833 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 22
過去 30 日: 99
今までの合計 4,327
