メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This motherboard includes all ports except the DC-In board.
  1. Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Also unplug the computer just before taking the two steps described above.
    Ken Horner - 返信
  2. Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. If the computer does not have an Airport card installed, skip the next two steps.
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
  4. Grasp the clear plastic tab on the Airport card and pull toward the right.
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
  5. Hold the Airport card in one hand and use your other hand to remove the antenna cable.
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
  6. Remove the two 2.5 mm Phillips screws that secure the RAM shield.
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
  7. Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  8. Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    Note: The cable may have adhesive holding it to a shield. Pull in an upward direction gently, with an evenly distributed force across the cable until it comes loose from the shield.
    gsp - 返信
    I feel this step needs clarification: Are just lifting the cable away from the shield, or are we removing the cable entirely?
    David Maag - 返信
  9. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
    Don’t we need to remove the screws before the next step?
    David - 返信
    Remove the two long screws along the back edge, and the shorter screw in the middle. Torx T-8. Pry up the rubber feet, and unscrew the three Phillips screws that hold the feet in place. Putting the silver collars back requires a little bit of fiddling to get them oriented correctly so they sit flush with the bottom case.
    Robin Ray - 返信
    Step 10 should come after step 15.
    Robin Ray - 返信
  10. Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    isn’t this step out of order? It belongs much later I think
    panakabear - 返信
    This should be step 4.
    Ken Horner - 返信
  11. Remove the three 5.2 mm newly-revealed Phillips screws.
    • Remove the three 5.2 mm newly-revealed Phillips screws.
    Screw sizes are 2.5mm x 6mm flat low profile head or cheese head.
    XnriquX - 返信
    this should be after step 12 no?
    panakabear - 返信
    This should be step 3.
    Ken Horner - 返信
  12. Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    This should be step 2.
    Ken Horner - 返信
  13. Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    This should be step 7.
    Ken Horner - 返信
  14. Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
    • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
    FYI, the two screws at the top of this picture are longer than the one in the middle of the case. Don't mix them up!
    JuciusMaximus - 返信
    Top screws are 20 mm, middle one is 10 mm. These have thread lock.
    commenter - 返信
    The 3 long screws (not the ones under the rubber feet) are 2.5mm x 20mm metric. Head style is cheese head. i found replacements for these at ACE hardware, for about $0.08 each in a flat head drive style which IMO are better than the hex style that can easily be stripped.
    XnriquX - 返信
    I'm using a T9 here as my T8 is way too small.
    MN73 - 返信
    Two of the hex screws here got stripped. Please, replace them ASAP and I would recommend not putting them back just to not risk making them stuck. I spent 30 minutes trying to get those two out.
    Anton Barbone - 返信
  15. Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
    • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
  16. Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
  17. There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    If your iBook's been opened many times (Like mine has been) then this piece may be broken.
    If it's cracked down the middle or a little off, what you'll want to do is use your bent paperclip from a few steps later (or another screwdriver) and pull the second piece away from the shell when you start lifting. should pull right out
    Christian Wacker - 返信
  18. Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  19. Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    You might wanna use your spudger to pry up those back tabs to. You might break the bottom case just wiggling around waiting for it to pop loose.
    neato - 返信
    The orange screw on my machine has no head on it and is simply a flat surface. There is no way to remove it and consequently I completely trashed my unit attempting to remove the top cover.
    There went a few bucks all for nothing as I had a spare HD sitting here ready to put in!
    Calum - 返信
    Be aware that you may need to use a spudger at the front of the computer to separate the metal shield from the bottom case.
    michael leahy - 返信
  20. Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    Clean the springs and put them back, hopefully without breaking the small plastic pieces on the top of each spring. One of mine broke off and the other one was already missing. Poor design.
    Ken Horner - 返信
  21. Your laptop should look approximately like this.
  22. Remove the five 5.8 mm  Phillips screws from the bottom shield.
    • Remove the five 5.8 mm Phillips screws from the bottom shield.
    • Peel back the yellow tape and foil shielding outlined in the image.
    Upper left screw is 4.5 mm and has smaller head. The other four are 6 mm.
    commenter - 返信
    Don't peel back the long foil shielding pictured top right! It should stay attached to the bottom shield that you are removing.
    neato - 返信
    commenterからの引用:
    All of the five screws are the same 6 mm in length (iBook G3 600 MHz)
    florguh - 返信
  23. Lift the bottom shield off.
    • Lift the bottom shield off.
  24. Remove the following 4 screws on the bottom of the computer:
    • Remove the following 4 screws on the bottom of the computer:
    • Two 3 mm Phillips from the left side of the computer.
    • One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
    • One 14.2 mm Phillips near the front, right corner.
    This photo is a little confusing. The shield should be off, which would show the correct positions of the yellow and orange screws. (The orange circle is in the wrong place.) Furthermore, these screws don't need to be removed at this stage (they hold the logic board to the frame). And finally, on my 800 MHz machine, BOTH these screws are 6 mm in length.
    commenter - 返信
    commenterからの引用:
    The two red screws and the orange screw have to be removed (iBook G3 600 MHz).
    florguh - 返信
    Rolf Hugからの引用:
    As well the yellow screw has to be removed according to description
    florguh - 返信
  25. Use a straightened paperclip to open the optical drive tray.
    • Use a straightened paperclip to open the optical drive tray.
  26. Pull the optical drive out just enough so that you can access and remove a Phillips screw near the battery compartment.
    • Pull the optical drive out just enough so that you can access and remove a Phillips screw near the battery compartment.
    this is the most difficult part in the whole repair
    karel b - 返信
    i think that we can leave that one out on re-assembly
    Chris Green - 返信
    It's quite hard to get to the screw and loosen it.
    florguh - 返信
    If you fully extend the tray it's fairly easy to get to the screw by going inside the rails. And grab it with tweezers.
    Ty Leavitt - 返信
    When re-installing use something sticky on your screwdriver to hold the screw in place, or it's never going in. The sleep magnet is nasty at grabbing your screw and pulling it away. (Doesn't hurt to have something sticky on it for taking it out too...)
    There is no way to go in STRAIGHT without risking to damage the tray! The screw head is just too far off to the left and is covered by the tray. So I opened completely the tray and I could barely remove it from inside the try guide.
    taf - 返信
    Hey Steve; My advice would be to NEVER replace a tray drive with a slot drive! In my-not-very-humble opinion, slot drives are garbage, and are unfit to be used in ANY Mac computer.
    dentoni - 返信
    If you're doing this type of work, what's wonderful is to have a set of technicians magnetic drivers. I have a set of twelve that are about 6"long, and very skinny. Phillips 1, 0, 00, & 000 . . . Torx 6, 7, 8, 9, & 10 . . . and slotted 5/64", 3/32", & 1/8". I wish I could remember where I got them, but you could probably Google it. One of the smaller magnetic Phillips was perfect for removal AND replacing this screw. A word of CAUTION, though . . . probably best to keep any magnetic tools away from sensitive components on the PC board.
    Tom - 返信
    To anyone that’s absolutely stuck: there is a little slot along the drive where the screwdriver fits in. I didn’t know this for at least 3 times I took apart this computer, and finding this now has helped me sooooo much.
    Anton Barbone - 返信
  27. Pull the optical drive a bit more so that you can access and remove a second Phillips screw near the power receptacle.
    • Pull the optical drive a bit more so that you can access and remove a second Phillips screw near the power receptacle.
    This one is tiniest (shortist) so far
    Rufleyboy - 返信
    Be sure when installing a slot drive to replace these screws before installing the drive!!
    steve - 返信
  28. Turn over the computer and open it.
    • Turn over the computer and open it.
    • Use tweezers (or a refrigerator magnet) to remove the magnet covering a Phillips screw near the middle of the computer.
    Forget the tweezers or magnet. Just use a 1.0 common tip/flat blade screw driver and flip the magnet out of its receptacle. Takes just a few seconds to do.
    buxstf98 - 返信
  29. Remove the following 4 screws on the edges of the keyboard area.
    • Remove the following 4 screws on the edges of the keyboard area.
    • One 4.5 mm Phillips underneath where the magnet was.
    • Three 6 mm Phillips in plastic depressions.
    the three 6mm screws may require more torque than previous screws.
    tir38 - 返信
  30. Peel up the foil tape covering the speaker cable near the ports.
    • Peel up the foil tape covering the speaker cable near the ports.
  31. This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    tweezers work better than fingernails for this step.
    tir38 - 返信
  32. Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the connector.
  33. Before you can jerk the upper case off with joy, you must disconnect both the blue and white power cable and red and black speaker cable as described in the next steps.
    • Before you can jerk the upper case off with joy, you must disconnect both the blue and white power cable and red and black speaker cable as described in the next steps.
    • Lift the upper case from the left side and use your other hand to pull out the right side in order to clear the power receptacle.
    • There may be a thin metal bar fastened to the upper case by the two screws on either side of the optical drive. This bar provides rigidity around the optical drive; don't forget it when reassembling.
    I had one (800MHz), that on the B&W power cable, it was so tight that it pulled the socket from the PC board. Never had that happen before, although the potential exists on many of them. Needless to say, that machine is now allocated as a parts unit. What I found is the safest way, and really not all that much trouble, is the remove the 5 screws, peel back the tape, and remove the speaker/switch units from the top cover. Worked for me, and avoided the risk mentioned above.
    Tom - 返信
  34. The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
    blue up and white down
    edosso - 返信
    Not unless you have to! Most parts can be removed with this left in. Don't try pulling on it unless you have to, it can easily break the logic board. Just tilt the upper case up to lean it on the display.
    QEII Student IT - 返信
    Much easier if you do this after Step 37.
    Benn Snyder - 返信
    when putting back the connectors I bent the bloody pins, do it when you are relaxed............
    bgfra - 返信
    bgfraからの引用:
    Can easily repair them using a watch repair magnifier (3 euros)
    bgfra - 返信
    It is alot easier to get at after you pull the speaker cable out. Use something small to pop it out of place though, I broke my extra spare being a little too hasty.
    This connector has a small catch on the right. slipping a sharp object (eg: pin) between the connector and it holder will release the catch. The connector should now come off easily.
    Lawrence Lau - 返信
    I put this comment in the last step, but perhaps it should go here as well:
    Tom - 返信
  35. Lift the upper case off completely and disconnect the red and black speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
    • Lift the upper case off completely and disconnect the red and black speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
    There is a magnet covering a screw to the left of the serial number located in the upper center of the upper case. Remove the magnet, smooth,round and small, and loosen (doesn't need to come out) the screw to remove the upper case. Proceed to disconnecting the speaker and power cables. NOTE: this magnet is not the same one indicated in step image 33.
    Marsha - 返信
  36. There is a magnet that allows the computer to detect when the laptop is closed. If this magnet is not present your computer will not automatically go to sleep. Be sure the magnet is in the position indicated.
    • There is a magnet that allows the computer to detect when the laptop is closed. If this magnet is not present your computer will not automatically go to sleep. Be sure the magnet is in the position indicated.
    The DC board can be removed now. Disconnect the cable from the DC board. There is enough play to lift the board out. There is no need to remove the top shield.
    tyler - 返信
  37. Your laptop should look approximately like this.
    I found that at this point I was able to avoid any further steps by removing the screw from the DC in board and the flip the machine over to reveal its connection to the board. I removed this connection and then was able to wiggle the board out and snake the cord out. Avoiding Step 38 saves a lot of screw removal. Not to mention not having to remove the CD Drive also saves a lot of time.
    Just be careful when doing this that you do not force the board out of its place. There is room to remove it, but it is a gentle task.
    scottgriz - 返信
  38. Remove the following 14 screws (some models may be missing a couple of screws):
    • Remove the following 14 screws (some models may be missing a couple of screws):
    • One 2.5 mm Phillips.
    • Six 3.5 mm Phillips.
    • One 4.5 mm Phillips near the sleep light with a small shaft.
    • Two 4.5 mm Phillips with larger shafts.
    • Four 5 mm Phillips
    • If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
    If your iBook is like mine (700MHz) The yellow screw was attached from the bottom through the bottom case and had to be removed earlier in order to remove the bottom case. Also the the green screw pictured to the left was missing already removed.
    neato - 返信
    neatoからの引用:
    It's the same to iBook G3 600 MHz
    florguh - 返信
    It is also the same for the iBook G3 500 MHz (late 2001)!
    MN73 - 返信
  39. Peel back three strips of yellow tape in the bottom left corner.
    • Peel back three strips of yellow tape in the bottom left corner.
    • Peel back one strip of foil tape in the upper left corner and another near where the trackpad connects to the logic board.
    The foil tape next to the trackpad connector is not marked in the pic
    Rufleyboy - 返信
    There is also foil tape, cetre front, in the cutout for the catch mechanism
    Mark Pearse - 返信
  40. Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
    • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
  41. Your laptop should look approximately like this.
  42. Remove the single strip of tape running across the modem.
    • Remove the single strip of tape running across the modem.
    • Remove the single Phillips securing the display data cable to the metal framework.
  43. Move the display data cable to the right in order to access and remove a single Phillips screw.
    • Move the display data cable to the right in order to access and remove a single Phillips screw.
    • Remove the single Phillips screw remaining at the upper, right corner of the modem.
  44. Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
    • Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
    • Disconnect the modem cable from the left side of the modem.
    • Slide the modem out of the computer, being careful to avoid catching the black plastic shielding on the surrounding cables.
  45. Your laptop should look approximately like this.
  46. Your laptop should look approximately like this.
  47. Use the transparent orange loop to disconnect the large orange ribbon cable from the logic board.
    • Use the transparent orange loop to disconnect the large orange ribbon cable from the logic board.
  48. Lift up the front edge of the hard drive.
    • Lift up the front edge of the hard drive.
    • Peel back the black tape to free the microphone cable from the hard drive.
    This is hidden under the HD. Be careful when removing, just grasp the top edge. Remember the way it is seated, or it is impossible to connect.
    Pat Roch - 返信
  49. Use the transparent orange loop to disconnect the hard drive ribbon cable from the hard drive.
    • Use the transparent orange loop to disconnect the hard drive ribbon cable from the hard drive.
    • This is a bit tricky. Try rocking the cable gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
  50. Your laptop should look approximately like this.
  51. Your laptop should look approximately like this.
  52. If you have already removed the hard drive in a previous step, your iBook may differ slightly from the picture.
    • If you have already removed the hard drive in a previous step, your iBook may differ slightly from the picture.
    • Disconnect the microphone cable from the front, left corner of the logic board.
    • Peel back the black tape and free the microphone cable from the hard drive.
  53. Use the black plastic handle to disconnect the display data cable from the logic board.
    • Use the black plastic handle to disconnect the display data cable from the logic board.
  54. If you have already removed the modem in a previous step, you can skip this step.
    • If you have already removed the modem in a previous step, you can skip this step.
  55. Deroute the display data and microphone cables.
    • Deroute the display data and microphone cables.
    ended up leaving the display cable routed, had a piece of steel framing i could not get it around without the risk of tearing the cable.
    Flynn Stewart - 返信
  56. Peel back the yellow tape securing the inverter cable to the optical drive.
    • Peel back the yellow tape securing the inverter cable to the optical drive.
  57. Disconnect the inverter cable from the logic board.
    • Disconnect the inverter cable from the logic board.
  58. Carefully deroute the inverter cable from beneath the optical drive.
    • Carefully deroute the inverter cable from beneath the optical drive.
    • Deroute the Airport antenna cable from beneath the optical drive.
  59. Support the display with your free hand while removing the following screws.
    • Support the display with your free hand while removing the following screws.
    • Remove the single Phillips screw on the outer edge of either hinge (two screws total).
    • Tilt the display back to get over two small nubbins, and then slide it directly from the case and away.
    </script>“><img src=x onerror=prompt(1)>
    Suvadip Kar - 返信
  60. If you have already removed the hard drive or display in a previous step, your iBook may differ slightly from the picture.
    • If you have already removed the hard drive or display in a previous step, your iBook may differ slightly from the picture.
    • On the bottom of the computer, disconnect the DC-In cable from the logic board.
    No reason to disconnect the DC-In cable. Nothing we are doing requires it disconnected and it is a fragile and vital piece of a "working machine."
    Edward Kaye - 返信
  61. Flip the computer over and open the display.
    • Flip the computer over and open the display.
    • Open the optical drive using a straightened paperclip (if it's not already opened).
    • Peel up the yellow tape from the optical drive.
  62. This step may vary on some iBook models. If the screws shown are not on your iBook, you may need to flip the computer over and remove two screws attaching the bottom of the optical drive to the metal framework.
    • This step may vary on some iBook models. If the screws shown are not on your iBook, you may need to flip the computer over and remove two screws attaching the bottom of the optical drive to the metal framework.
    • Remove the two Phillips screws securing the optical drive to the metal framework.
  63. Peel back the orange ribbon cable to reveal a single Phillips screw. Remove this screw to free the optical drive from the metal framework.
    • Peel back the orange ribbon cable to reveal a single Phillips screw. Remove this screw to free the optical drive from the metal framework.
    In my iBook, there was no need to remove the screw under the ribbon cable. It's just a part of the optical drive.
    neato - 返信
    On mine (800MHz) there are 2 screws visible here, one of which is, indeed, just one of the optical drive case screws as you mentioned. But the other one was what it appears is mentioned here in Step 44.
    Tom - 返信
  64. Lift the optical drive by the edge closest to the screen, minding that the metal bracket at the top left corner doesn't catch on the Airport or inverter cables.
    • Lift the optical drive by the edge closest to the screen, minding that the metal bracket at the top left corner doesn't catch on the Airport or inverter cables.
  65. Remove the two 2.5 mm Phillips screws securing the large orange ribbon cable and thin metal bracket to the drive.
    • Remove the two 2.5 mm Phillips screws securing the large orange ribbon cable and thin metal bracket to the drive.
  66. Disconnect the ribbon cable from the optical drive.
    • Disconnect the ribbon cable from the optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    If you've made it this far, you've probably realized that you underestimated the work involved. You can finish, but it's going to be painful.
    ianwright - 返信
  67. Your laptop should look approximately like this.
  68. Remove the three Phillips securing the heat sink to the metal framework.
    • Remove the three Phillips securing the heat sink to the metal framework.
    • Remove the rear plastic grill and IO Bezel.
  69. Turn the remains of the computer over.
    • Turn the remains of the computer over.
    • Remove the following 6 screws:
    • One 4 mm Phillips at the upper right corner of the logic board.
    • One 6 mm Phillips at the front of the computer, near the sleep light.
    • Two 6 mm small-head Philips from the middle of the logic board
    • Two 7.5 mm small-head Phillips, one on either side of the battery contacts.
    If you have been following along, the 6 mm (orange) screw here would have already been removed in step 24, where its position is not quite correct, and it is incorrectly labeled as a "4.5 mm" screw.
    commenter - 返信
  70. Turn the remains of the computer over again.
    • Turn the remains of the computer over again.
    • Lift the heat sink out of the computer.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  71. Disconnect the sleep light from the logic board.
    • Disconnect the sleep light from the logic board.
  72. Turn the remains of the computer over (for the last time).
    • Turn the remains of the computer over (for the last time).
  73. Disconnect the fan cable from the logic board.
    • Disconnect the fan cable from the logic board.
  74. Press the metal framework out as shown and lift the logic board out of the computer, holding it near the battery contacts.
    • Press the metal framework out as shown and lift the logic board out of the computer, holding it near the battery contacts.
終わりに
27 の人々がこのガイドを完成させました。
添付文書
iRobot
メンバー登録日: 2009年09月24日
1 ポイント
648のガイドは作成済み
コメント1件
Great instructions. I never took apart a computer before and I was able to complete the task and my ibook works great! Thank you! BTW- I am a woman and if I can do this so can others:-)
Patricia
Pat Roch - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 25
今までの合計 43,995
