メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
アーカイブ済み
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
アーカイブ済み
はじめに
This guide has some missing steps. Check out the comprehensive iPhone 4S Screen Replacement Guide.
パーツ
パーツは指定されていません。
  1. I phone 4s, A1837 Magnetic Screw Mat Magnetic Screw Mat
    • I phone 4s, A1837
    • Magnetic Screw Mat
  2. Remove 2 X pentalobe screws Remove 2 X pentalobe screws Remove 2 X pentalobe screws
    • Remove 2 X pentalobe screws
  3. Slide rear cover up and remove Slide rear cover up and remove
    • Slide rear cover up and remove
  4. Remove 2 X Philips screws Remove connector Remove connector
    • Remove 2 X Philips screws
    • Remove connector
  5. Pull battery removal tab up to remove battery Pull battery removal tab up to remove battery Pull battery removal tab up to remove battery
    • Pull battery removal tab up to remove battery
  6. Remove 2 X Philips screws and plate Pop up connector and slide tool underneath ribbon cable to remove glue Pop up connector and slide tool underneath ribbon cable to remove glue
    • Remove 2 X Philips screws and plate
    • Pop up connector and slide tool underneath ribbon cable to remove glue
  7. Remove wifi antenna Remove wifi antenna Remove wifi antenna
    • Remove wifi antenna
  8. Remove camera and Sim card Remove camera and Sim card Remove camera and Sim card
    • Remove camera and Sim card
  9. Pop up 6 connectors at the top
    • Pop up 6 connectors at the top
  10. Remove 2 X screws and triangular washer Remove 2 X screws and triangular washer
    • Remove 2 X screws and triangular washer
  11. Heat vibrator and pry up Heat vibrator and pry up
    • Heat vibrator and pry up
  12. Remove 10 X Philips screws Remove 10 X Philips screws
    • Remove 10 X Philips screws
終わりに
6 の人々がこのガイドを完成させました。
Shane
メンバー登録日: 2012年01月30日
844 ポイント
1ガイドが承認済み
チーム
Smart Screens Smart Screens人のメンバー
Business
1 メンバー
1のガイドは作成済み
コメント1件
I know the user had good intentions, but this is a low quality guide. Low lighting, super vagueness in steps, not all steps necessary are listed, screws to remove, harmful surprises to expect etc. If you want to replace your screen successfully with confidence and ease, use ifixit's staff guide: iPhone 4S スクリーンの交換
lucasproul - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,883
