メインコンテンツにスキップ
hp pavilion 15-cc023cl Headphone Jack Replacement
必要な工具と部品
  1. hp pavilion 15-cc023cl Headphone Jack Replacement, Battery: 手順 1、 2の画像 1 hp pavilion 15-cc023cl Headphone Jack Replacement, Battery: 手順 1、 2の画像 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 2、 1の画像 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 3、 2の画像 1 hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 3、 2の画像 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 4、 2の画像 1 hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 4、 2の画像 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Headphone Jack Replacement, Hard Drive: 手順 5、 1の画像 1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 7、 1の画像 1
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 8、 1の画像 1
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Headphone Jack Replacement, Motherboard: 手順 9、 1の画像 1
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 10、 2の画像 1 hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 10、 2の画像 2
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 11、 1の画像 1
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 12、 1の画像 1
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 13、 1の画像 1
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 14、 3の画像 1 hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 14、 3の画像 2 hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 14、 3の画像 3
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 15、 2の画像 1 hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 15、 2の画像 2
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 16、 1の画像 1
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Headphone Jack Replacement: 手順 17、 1の画像 1
    • Disconnect SD and USB card cable.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Stephanie Henry
メンバー登録日: 10/02/18
1,077 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team S2-G6, Munoz Fall 2018 Eastern Washington University, Team S2-G6, Munoz Fall 2018人のメンバー
EWU-MUNOZ-F18S2G6
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 1,707
