はじめに
After performing all possible software troubleshooting, if you're headphone jack still doesn't work, you will have to replace the entire motherboard because the jack is permanently attached to the motherboard.
必要な工具と部品
Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
