メインコンテンツにスキップ
ヘルプ
iPhone X Disassembly
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
This tutorial is about how to tear down iPhone X.
  • 作成者: Mandy
  • 難易度: 普通
Basic disassembly tutorial for iPhone X.
手順 1 Turn off the phone and remove SIM Card  ¶
Press the wake button and volume down button to turn off the phone. Press the wake button and volume down button to turn off the phone.
  • Press the wake button and volume down button to turn off the phone.
手順 2 Open the phone  ¶
Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened. Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened. Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
  • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
手順 3 Remove the iPhone X OLED screen  ¶
Undo 5 screws shown in the picture below with a triangle screwdriver Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger. Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
  • Undo 5 screws shown in the picture below with a triangle screwdriver
  • Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
手順 4 Remove the ear speaker  ¶
Undo 3 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily Undo 3 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
  • Undo 3 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
手順 5 Remove rear-facing cameras.  ¶
Remove 2 screws and remove the metal plate, release the rear cameras connectors.
  • Remove 2 screws and remove the metal plate, release the rear cameras connectors.
手順 6 Remove motherboard.  ¶
Release all connectors on the motherboard with a spudger Undo 3 screws on the mother board then we can take out the mother board.
  • Release all connectors on the motherboard with a spudger
  • Undo 3 screws on the mother board then we can take out the mother board.
手順 7 Remove Loudspeaker and Taptic engine  ¶
Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine Remove the loud speaker and the taptic engine. Remove the loud speaker and the taptic engine.
  • Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
  • Remove the loud speaker and the taptic engine.
手順 8 Remove battery  ¶
Pulling out 4 battery adhesives with a tweezers then we can remove the battery. Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
  • Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
手順 9 Remove front-facing camera  ¶
Heating the front facing camera with a heat gun will make it easily to be removed Heating the front facing camera with a heat gun will make it easily to be removed
  • Heating the front facing camera with a heat gun will make it easily to be removed
手順 10 Remove the charging port and antenna  ¶
Release 4 screws on the frame shown in the picture Heating the charging port flex  cable then we can remove it easily Heating the charging port flex  cable then we can remove it easily
  • Release 4 screws on the frame shown in the picture
  • Heating the charging port flex cable then we can remove it easily
手順 11 Remove Wi-Fi antenna  ¶
Release 7 screws on the Wi-Fi flex cable Heating the flex cable with a heat gun make it easier to be removed Heating the flex cable with a heat gun make it easier to be removed
  • Release 7 screws on the Wi-Fi flex cable
  • Heating the flex cable with a heat gun make it easier to be removed
手順 12 Remove power button flex cable  ¶
Release 3 screws on the power button Heating the flex cable with a heat gun then it can be removed easily Heating the flex cable with a heat gun then it can be removed easily
  • Release 3 screws on the power button
  • Heating the flex cable with a heat gun then it can be removed easily
