メインコンテンツにスキップ
ヘルプ
HP 2000-2d19wm Keyboard Replacement
進行中
進行中
このガイドは現在作成中です。最新の変更を見るために定期的に再読み込みしてください。
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
How to replace a keyboard on HP 2000-2d19WM
  • 作成者: Walker Young
  • 所要時間: 15分
  • 難易度: 簡単
How to replace a broken keyboard on an HP computer
手順 1 Keyboard  ¶
First make sure you have a clear work space Make sure you have all of the tools to do this job!  If not you may break something else doing this Repair
手順 1 Keyboard  ¶
  • First make sure you have a clear work space
  • Make sure you have all of the tools to do this job! If not you may break something else doing this Repair
  • Not all the tools in the picture I needed.
手順 2  ¶
My keyboard is kind of bad so the general idea is to get a flat bladed screwdriver under Neath of the old keyboard not the keys it may help if you take all of the old keys  off around the sides
手順 2  ¶
  • My keyboard is kind of bad so the general idea is to get a flat bladed screwdriver under Neath of the old keyboard not the keys it may help if you take all of the old keys off around the sides
手順 3  ¶
pry Up on the old keyboard until you see the 5 pins pop up out of place once all 5 come undone the old key board should come right out pry Up on the old keyboard until you see the 5 pins pop up out of place once all 5 come undone the old key board should come right out
手順 3  ¶
  • pry Up on the old keyboard until you see the 5 pins pop up out of place once all 5 come undone the old key board should come right out
手順 4  ¶
Now the old keyboard is out.
手順 4  ¶
  • Now the old keyboard is out.
手順 5  ¶
Put the pins of the new keyboard in then put it back into place as the old one was. Put the pins of the new keyboard in then put it back into place as the old one was. Put the pins of the new keyboard in then put it back into place as the old one was.
手順 5  ¶
  • Put the pins of the new keyboard in then put it back into place as the old one was.
手順 6  ¶
That’s the end your laptop should be working just right now one thing I forgot to mention was you had to plug the cable on the keyboard back in if you did not do so your keyboard definitely will not work.
手順 6  ¶
  • That’s the end your laptop should be working just right now one thing I forgot to mention was you had to plug the cable on the keyboard back in if you did not do so your keyboard definitely will not work.
