メインコンテンツにスキップ
ヘルプ
iMac G5 17" Model A1058 PRAM Battery Replacement
Use this guide to replace your PRAM battery.
セクション
手順 1 PRAM Battery  ¶
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
手順 1 PRAM Battery  ¶
  • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
手順 2  ¶
Slightly lift the AirPort bracket off the logic board.
手順 2  ¶
  • Slightly lift the AirPort bracket off the logic board.
  • De-route the AirPort antenna through the slot in the AirPort bracket.
手順 3  ¶
Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
手順 3  ¶
  • Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
  • Do not bend the metal retaining clip up, as it is brittle and will break.
  • Use another spudger to slide the PRAM battery out from under its socket's retaining clip.
