メインコンテンツにスキップ
ヘルプ
PowerBook G4 Titanium DVI DC-In Board Replacement
  • 作成者: iRobot
  • 難易度: 普通
Tripped over your power cord? At least you don't have to replace the entire logic board.
セクション
ファイル
手順 1 DC-In Board  ¶
Disconnect the large DC-In connector from the right side of the logic board.
手順 1 DC-In Board  ¶
  • Disconnect the large DC-In connector from the right side of the logic board.
手順 2  ¶
Remove the two T6 Torx screws from the DC-In board.
手順 2  ¶
  • Remove the two T6 Torx screws from the DC-In board.
手順 3  ¶
Lift the DC-In board out of the computer by pulling up and away from you.
手順 3  ¶
  • Lift the DC-In board out of the computer by pulling up and away from you.
  • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
  • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
