メインコンテンツにスキップ
ヘルプ
Casio Exilim EX Z55 Front Case Replacement
文法の修正
文法の修正
あなたの中にある日本語能力を呼び起こし、このガイドの文法に磨きをかけましょう。
How to replace or remove the front case of this camera. (Front and Back case come off simultaneously)
This guide shows how to remove the front case from the rest of the camera. You may have to do this to replace a damaged front cover or to access the inner parts of the camera.
手順 1 Front Case  ¶
Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom.
手順 1 Front Case  ¶
  • Locate 12 screws. Four on the left, four on the right, and four on the bottom.
手順 2  ¶
Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
手順 2  ¶
  • Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
手順 3  ¶
Separate the front case from the body of the camera.
手順 3  ¶
  • Separate the front case from the body of the camera.
