メインコンテンツにスキップ
ヘルプ
Samsung Ace Display Screen Replacement
Installing a new LCD Screen.
  • 作成者: Breanne
  • 所要時間: 15 - 20 分
  • 難易度: 普通
If the main display on your phone is cracked, depicting a frozen image, or not displaying an image at all, then installing a new display may fix these problems.
セクション
ツール
手順 1 Display Screen  ¶
Locate the display screen. Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
  • Locate the display screen.
  • Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
  • It may help to insert the pointed edge of the spudger into the small indentation shown on the right in the second image.
手順 2  ¶
Slide the spudger across the bottom of the display and slowly push up. Slide the spudger across the bottom of the display and slowly push up. Slide the spudger across the bottom of the display and slowly push up.
手順 2  ¶
  • Slide the spudger across the bottom of the display and slowly push up.
手順 3  ¶
Slowly pry the spudger up to remove the display.
手順 3  ¶
  • Slowly pry the spudger up to remove the display.
手順 4  ¶
To remove the casing as a whole, slowly lift up and towards the right side of the phone.
手順 4  ¶
  • To remove the casing as a whole, slowly lift up and towards the right side of the phone.
  • Be aware of the wiring on the right side of the phone connecting the display.
