メインコンテンツにスキップ
ヘルプ
Apple AirPort Extreme Model A1354 Antenna Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
This guide explains how to access and remove an antenna so that it can be replaced.
  • 作成者: Brandon
  • 所要時間: 5分
  • 難易度: 普通
If the base station is sending out a poor signal, an antenna may need to be replaced.
手順 1 Antenna  ¶
Remove the metal casing by gently prying the logic board away with you hands.
手順 1 Antenna  ¶
  • Remove the metal casing by gently prying the logic board away with you hands.
  • This should be pretty easy, you already removed the screws holding these pieces together.
手順 2  ¶
Turn the device so that the antenna to be replaced is facing you. Turn the device so that the antenna to be replaced is facing you.
手順 2  ¶
  • Turn the device so that the antenna to be replaced is facing you.
手順 3  ¶
Caution: Be careful not to bend the metal strip that the antenna is attached to. This may cause problems during reassembly and use.
手順 3  ¶
  • Caution: Be careful not to bend the metal strip that the antenna is attached to. This may cause problems during reassembly and use.
  • Using the screwdriver, unscrew the 2.5mm Phillips screw on the antenna.
手順 4  ¶
Turn the device over so that the antenna with the screw removed is still facing you.
手順 4  ¶
  • Turn the device over so that the antenna with the screw removed is still facing you.
手順 5  ¶
Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
手順 5  ¶
  • Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
手順 6  ¶
Carefully peel back the clear yellow tape covering the  cable of the antenna to be removed. Carefully peel back the clear yellow tape covering the  cable of the antenna to be removed.
手順 6  ¶
  • Carefully peel back the clear yellow tape covering the cable of the antenna to be removed.
手順 7  ¶
Remove the antenna.
手順 7  ¶
  • Remove the antenna.
