メインコンテンツにスキップ
ヘルプ
Motion Computing LE1600 Battery Replacement
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
In this guide you will learn how to remove the battery from the device, as well as replace it.
  • 作成者: David Troy
  • 所要時間: 1分
  • 難易度: とても簡単
Before you start anything, you should always remove the battery. This guide will take you through this process.
手順 1 Battery  ¶
Turn the device so the screen is facing down.
手順 1 Battery  ¶
  • Turn the device so the screen is facing down.
手順 2  ¶
Slide the battery lock switch next to the power slider to the unlocked position. Slide the battery lock switch next to the power slider to the unlocked position.
手順 2  ¶
  • Slide the battery lock switch next to the power slider to the unlocked position.
手順 3  ¶
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
手順 3  ¶
  • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
  • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
