メインコンテンツにスキップ
ヘルプ
iHome IBT16 Battery Replacement
This guide will teach you the steps needed to replace a bad battery within the iHome iBT16.
  • 作成者: Steven Ferreira
  • 所要時間: 5 - 35 分
  • 難易度: 難しい
This guide will teach you how to correctly remove the battery for this device.
手順 1 Battery  ¶
Inside the iHome remove the two 10mm silver Phillips screws that are on the motherboard.
手順 1 Battery  ¶
  • Inside the iHome remove the two 10mm silver Phillips screws that are on the motherboard.
  • Connect the ground strap to earth ground and put it around your wrist.
手順 2  ¶
Take the motherboard out of the device, use the Plastic opening tool to ensure the power switch doesn't get stuck.
手順 2  ¶
  • Take the motherboard out of the device, use the Plastic opening tool to ensure the power switch doesn't get stuck.
  • Don't pull too hard as you could possibly rip some wires or break the switch.
手順 3  ¶
Take the battery out from underneath the motherboard.
手順 3  ¶
  • Take the battery out from underneath the motherboard.
  • The battery is connected to the motherboard, don't pull the battery too hard or too far from the motherboard.
手順 4  ¶
Unsolder the black and red wires that are connected to the motherboard.
手順 4  ¶
  • Unsolder the black and red wires that are connected to the motherboard.
  • Don't hold the soldering iron to the solder joints for more than 10 seconds at a time.
手順 5  ¶
Remove the bad battery by unsoldering the red wire from the B+ solder joint and the black wire from the B-
手順 5  ¶
  • Remove the bad battery by unsoldering the red wire from the B+ solder joint and the black wire from the B-
