メインコンテンツにスキップ
ヘルプ
MacBook Air Models A1237 and A1304 Battery Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
  • 作成者: Walter Galan
  • 所要時間: 15分
  • 難易度: 普通
Don't pay Apple to replace your worn out battery. Do it yourself!
手順 1 Battery  ¶
Disconnect the battery connector by pulling it straight out of its socket.
手順 1 Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
手順 2  ¶
Remove the following nine screws securing the battery to the Air:
手順 2  ¶
  • Remove the following nine screws securing the battery to the Air:
  • Four 2.9 mm Phillips.
  • Four 3.8 mm Phillips.
  • One 7.2 mm Phillips.
手順 3  ¶
Lift the battery out of the Air.
手順 3  ¶
  • Lift the battery out of the Air.
  • If you're installing a new battery, you should calibrate it after installation:
  • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
