メインコンテンツにスキップ
ヘルプ
Huawei P9 Lite Motherboard Replacement
Replace the motherboard in your Huawei P9 Lite
Use this guide to replace the motherboard in your Huawei P9 Lite.
手順 1 Motherboard  ¶
Remove the SIM card tray. Remove the SIM card tray.
手順 1 Motherboard  ¶
  • Remove the SIM card tray.
手順 2  ¶
Disconnect the motherboard flex, the battery flex and the antenna cable. Disconnect the motherboard flex, the battery flex and the antenna cable. Disconnect the motherboard flex, the battery flex and the antenna cable.
手順 2  ¶
  • Disconnect the motherboard flex, the battery flex and the antenna cable.
手順 3  ¶
Disconnect the display flex and the power and volume button cable. Disconnect the display flex and the power and volume button cable.
手順 3  ¶
  • Disconnect the display flex and the power and volume button cable.
手順 4  ¶
Unplug the rear camera and the headphone jack. Unplug the rear camera and the headphone jack.
手順 4  ¶
  • Unplug the rear camera and the headphone jack.
手順 5  ¶
Take the camera and the headphone jack out of their recesses. Take the camera and the headphone jack out of their recesses.
手順 5  ¶
  • Take the camera and the headphone jack out of their recesses.
手順 6  ¶
Use a spudger to lift the motherboard carefully. Remove the motherboard assembly. On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If you are about to replace the display assembly, and the thermal pad broke or is too dried out, you might want to replace it with a new one.
手順 6  ¶
  • Use a spudger to lift the motherboard carefully.
  • Remove the motherboard assembly.
  • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If you are about to replace the display assembly, and the thermal pad broke or is too dried out, you might want to replace it with a new one.
