メインコンテンツにスキップ
ヘルプ
Huawei P9 Lite Back Cover Replacement
Replace the back cover of your Huawei P9 Lite.
Use this guide to replace the back cover of your Huawei P9 Lite.
手順 1 Back Cover  ¶
Use an opening pick to unclip the rear cover, starting from the bottom corner. Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
手順 1 Back Cover  ¶
  • Use an opening pick to unclip the rear cover, starting from the bottom corner.
  • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
手順 2  ¶
There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
手順 2  ¶
  • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
  • Be careful with the flex cable at the right hand side.
  • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
手順 3  ¶
When the back cover is freed from the adhesive you can pop it off by hand completely.
手順 3  ¶
  • When the back cover is freed from the adhesive you can pop it off by hand completely.
