メインコンテンツにスキップ
ヘルプ
iPhone 3GS Earpiece Speaker Replacement
Replace your iPhone 3GS's earpiece speaker.
Has your ear speaker stopped working? Follow this guide to install a new one.
セクション
手順 1 Earpiece Speaker  ¶
Remove the single Phillips #00 screw from the corner of the display assembly.
  • Remove the single Phillips #00 screw from the corner of the display assembly.
手順 2  ¶
Use the flat end of a spudger to pry up the right side of the ear speaker cover assembly. Do not try to pry the assembly all the way off, as it is still connected at two points. Turn the spudger around and use the pointed side to detach the two clips securing the top of the assembly.
手順 2  ¶
  • Use the flat end of a spudger to pry up the right side of the ear speaker cover assembly.
  • Do not try to pry the assembly all the way off, as it is still connected at two points.
  • Turn the spudger around and use the pointed side to detach the two clips securing the top of the assembly.
  • Once the clips are detached, lift the cover assembly up from the device.
手順 3  ¶
Slide the pointed end of the spudger into the slot under the upper right corner of the ear speaker and gently pry upwards. Be careful during this step, as the upper portion of the speaker can easily detach from the lower portion, causing the coil inside to unwind. Be sure to pry the entire assembly up.
手順 3  ¶
  • Slide the pointed end of the spudger into the slot under the upper right corner of the ear speaker and gently pry upwards.
  • Be careful during this step, as the upper portion of the speaker can easily detach from the lower portion, causing the coil inside to unwind. Be sure to pry the entire assembly up.
  • Lift the ear speaker up and out of the device.
