メインコンテンツにスキップ
ヘルプ
Dell Dimension 4600 Side Panel Replacement
This guide will teach you to open the case of your Dell Dimension 4600 to access the internal parts.
  • 作成者: Daniel Crawford
  • 所要時間: 5分
  • 難易度: とても簡単
Use this guide to remove the side panel from the computer and gain access to the internal components.
手順 1 Side Panel  ¶
Locate the case cover latch on the back of the computer.
手順 1 Side Panel  ¶
  • Locate the case cover latch on the back of the computer.
手順 2  ¶
Using your index finger, slide and hold the cover latch down.
手順 2  ¶
  • Using your index finger, slide and hold the cover latch down.
  • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
手順 3  ¶
Grab the edge of the panel and slide it away from the case until it is removed.
手順 3  ¶
  • Grab the edge of the panel and slide it away from the case until it is removed.
